Hi all,
Does anyone have a Mazda guide (pdf or so) which shows how to dismantle the side mirrors in order for me to change the turn signal indicators?
Thanks in advance
Guide for side mirror dismantling
Hi Batcave,
a user of the CX5-Forum postet a discription of his attempt to repair a broken folding-mechanism of one of his side mirrors. In this context he also shows how to disassamble the mirror casing:
First you have to remove the mirror glass (?) in order to unclip the rear cover to get to the turn signal indicators ( I'm not quite shure if removing of the mirror glass ist necessary - maybe the rear cover and the housing are just clipped together and can be pulled apart by means of a flat tool to be put between rear cover and housing. Try carefully...)Even though the side mirrors of CX-5 and CX-3 are not identical they are still similar and the pictures may help you:
https://www.cx5-forum.de/f10/a…egel-reparieren-1921.htmlRegards Wolfgang (Schrauberopa)
If removing of the mirror glass should be necessary, i found this:
http://www.mcx5.org/outer_mirror_glass_removal-734.htmlAnd this concerning the removal of the rear cover:
http://www.mcx5.org/outer_mirr…val_installation-730.html
