MZD Version 59.00.443 EU N
  • Habe folgendes azu gefunden: 59 is only a system update that fixes mostly bug issues such as nav acting funny (freezing/blackout/thinks you are in a a different country), optimizing the infotainment (speed) and minor stuff like that.
    Und auch folgendes:
    Firmware CHANGELOG for NA_59.00.441A
    • DTC U0100:00 [CONNECTIVITY MASTER UNIT] (communication error with PCM) is stored in memory.
    • Warning guidance's are displayed both for LDWS and HBC (CX-3 with LDWS and without HBC only).
    • Improper OFF selection in the Setting Interval menu under Oil Change (TC CX-9 only).
    • Resetting with “Fixed” data will not reset “Flexible” data. (TC CX-9 only).
    • Tachometer function has been removed from the Active Driving Display (TC CX-9).*
    • Navigation or other screens freeze or reboot.
    • Issues with Pandora Radio.
    • USB device fails to start playing, resume or display music information.
    • BT audio device fails when starting to play, resume or connect.
    • Paired BT device will not connect. Removing the paired BT device from the vehicle (but not the vehicle from the phone) results in an endless “Deleting” message.
    *To improve safety and reduce driver distraction.
